I am looking for the leafspring center pin diameter and length and also the ubolt dimensions. I need these ASAP. Please help!!
http://thenewx.org/phpbb2/viewtopic.php?t=6375&highlight=ubolt[email protected] said:I am looking for the leafspring center pin diameter and length and also the ubolt dimensions. I need these ASAP. Please help!!
Do you sell them when we order the deavers from you?PrerunnerGreg said:Center pin posted above. You can use a 3/8-24 SHCS also, be sure to get new nuts. as for the u-bolts, stock is 12mm rod 80mm spread by 165mm long. Or 3.25 spread by 6.5" long, 1/2 rod.
ner mind, socket head cap screw.PrerunnerGreg said:Center pin posted above. You can use a 3/8-24 SHCS also, be sure to get new nuts. as for the u-bolts, stock is 12mm rod 80mm spread by 165mm long. Or 3.25 spread by 6.5" long, 1/2 rod.
Totally different process used in creating the threads.bhbeecham said:u bolts are fine. if not replace all of your tire luggs when you take off a tire
