Copy that. Setup looks good then, buddy
1. The Cobra 75 WXST is a good choice for an Xterra.Ok so it's Christmas list time. Here's what I'm thinking.
Cobra 75WXST 40-Channel CB
Diamond K400-3/8C2 antennae mount (13.5" of Cable)
Firestik 4' Antennae
Firestik HD Spring
Wanting opinions.
That whole tray just pops out. And that's just a face plate FYI not a full body.For guys that mounted their radios under the center dash, how did you access the cavity prior to drilling for the bracket?
I was hoping to mount my radio from the dash (above) ... not the tray.That whole tray just pops out. And that's just a face plate FYI not a full body.
This is mine, I did it all in vehicle. Mocked it up where I wanted it, marked where the bracket was, removed the cb from the bracket and marked the holes, then used a ratcheting bit driver and pressure to get the screws in. The hard part, for me, was getting the hole in the lower piece for the antenna cable through but if you are an automatic you can mount the radio further out.For guys that mounted their radios under the center dash, how did you access the cavity prior to drilling for the bracket?
Right. I'll look into the magnetic mounts. I'd rather have a firestik on the hood and not add the extra height than have a magnetic mount on the roof plus 2-3 feet. I've heard great reviews on the firestik too.Note: Whether hard mount or magnetic mount, every CB antenna needs to be tuned.
Now I need to look up how to tune the antenna.
Looking to set up a cheap CB Radio in the Xterra.
This CB:
https://www.amazon.com/Uniden-40-Ch...=UTF8&qid=1483042596&sr=1-4&keywords=cb+radio
With this Antenna:
https://www.amazon.com/TRAM-703-HC-...coding=UTF8&psc=1&refRID=4SRZNX2WAZ1A19STEQ90
Or, I'm thinking a 3' Firestik with a hood mount.
If you get the Uniden 520XL it will fit in the center console if you want a clean stealth install.If you want a Uniden, my recommendation would be the Pro510XL or Pro520XL for just a few dollars more.
Tram antennas are OK, but just OK.
The CB antenna is actually more important than the radio in terms of transmission/reception quality. If you want to use a magnetic mount you might consider the Wilson "Little Wil" or the K30 instead of a Tram.
https://www.rightchannelradios.com/collections/magnet-mount-cb-antennas
[There is nothing wrong with using a quality mag mount antenna for occasional CB use. A rooftop mount works better in theory, but the cost/benefit/convenience analysis sometimes favors the simplist solution.]
All hard mounted antennas should have a spring to prevent damage when encountering a hard object such as a tree branch, garage door header, drive through overhang, etc.. . . As for the rooftop antenna, what are the chances of damaging the antenna on low clearances.
A Wilson lil Wil will bend over 90° less than 6" from the magmount and still hold.All hard mounted antennas should have a spring to prevent damage when encountering a hard object such as a tree branch, garage door header, drive through overhang, etc.
A mag mount antenna will simply tip over. Chances of damage at low speeds are minimal.
