1 - 4 of 4 Posts
To remove the roof rails, do you remove the plastic part holding the rails at the rear of the truck and slide them out of the front box ( even with the angled part ), or you still have to remove the roof box also to be able to take them out ?
Each plastic part has bolts holding the rail to it. So you have to remove all the plastic feet from the roof then remove the rail from the feet. The larger front section is 2 parts.
A couple pics from when I took them off to put wires in them for back up lights.
You can see the hole for the bolt securing to rear foot.
2 bolts holes on side for large front section.
These were taken 3 years ago, given there are 4 bolts off to the side in the picture there may be 3 holding the front section. I didn’t need to remove the middle foot.
1 - 4 of 4 Posts
