Hi gang- in need of new tires ASAP for some wheelin soon by Ouray, and I'm ready to make the jump to 33's. I'm worried my 2" lift won't give me enough room. Details below, and a little bit of background:
Details:
Background:
I've been rocking my 'road-ish' 31" tires that came with my 2015 Pro-4X for a while now, because they've worked okay and there was no reason to upgrade. While driving to go skiing on the 4th of July at Peak 10 of the Tenmile Range (above Breckenridge), I shredded a sidewall of my back left tire (lots of traffic on the trail to 12,600', and someone didn't quite pull over far enough so I ended up sorta dragging the tire along a steep trail wall- long story). With a full-size spare (conveniently mounted to my swinggate), swapping it out was a jiffy and I've been parading my wrektt wheel around for a few weeks.
Fast forward 2 weeks... doin some wheelin to go camping above Winter Park (biking Trestle downhill that weekend), and I made a nasty gouge into my wheel sidewall again!! I can see some of the ply, although I've been driving on it still for a couple weeks without catastrophic failure yet. Needless to day, I need new wheels, and now is the time to upgrade.
I have actually bought a daily driver ('07 Mazda 3) for work, and I am mainly leaving my X in the garage during the week- it's been great! I also have been regularly getting 21mpg on it (although my last tank was 23mpg, since I'm driving it gingerly), and I don't mind a larger tire diameter since with the 6-speed I can kinda drive it different to compensate for the size. My point is that I have no holds getting gnarlier wheels that might make it a little more inconvenient for a daily driver / gas mileage (although I'm not trying to turn this thing into a mudder).
So, can I fit 33's? Maybe I have to adjust the bump stops up front. If so, what tire should I get? I feel like getting a higher ply would fix my problems, any suggestions? Sorry for the rant! I've had about 8 threads in my mind I've been meaning to post, just finally got around to this one since it's urgent. Cheers, fellas!
I obviously have more photos of my X (like, way too many), so if an expert needs to see a different angle lemme know haha. Mathematically, I definitely have room for the extra 1", but I'm sure it's not that simple. Also probably gonna do black steelies for rims, or some other cool black rim (suggestions?)
Details:
- Coastal Offroad rear bumper (with dual swinggates, although irrelevent)
- Shrockworks front bumper
- OME suspension, with new leaf pack +1 add-a-leaf, and new front upper control arms
- I understand it to be 2" rear life, 1 1/2" front lift
- see photos, where I'm rocking tires that go to about 31"
Background:
