One solution but not sure on reliability or compatibility with off road use.
Remco's Drive Shaft Coupling
Prevents automatic transmission damage to your rear axle drive vehicle. When you tow your rear axle drive car, van or pickup, the drive shaft to the rear axle must be disconnected to prevent damage to the automatic transmission. This requires mechanical service under the car which is not convenient for RV towing. Remco's Drive Shaft Couplings was developed to provide a quick and easy means of disconnecting the transmission while sitting in the driver's seat. The coupling (mechanical clutch) is installed into the rear portion of the car's drive shaft, near the rear axle.
When disconnected the rear axle is free to turn without turning the drive shaft or transmission. The coupling has a control cable attached to it which extends to a location under the driver's seat. This control is pulled out to disengage for towing and pushed into engage for driving the vehicle.
No Transmission damage while towing
No speedometer miles while towing
Shift to drive or tow in seconds
Coupling made with heat treated alloy steel
Precision cut gear teeth
Lifetime sealed ball bearings
Fits most rear wheel drive cars, vans or pickups
Purchase with new shaft attached or we can modify your existing driveshaft
Over 50,000 units on the road in 14 years
Easy installation by a garage or an above average weekend mechanic call order the unit with a small deposit, remove your existing driveline and send it to us via UPS. We will modify your existing shaft and UPS it back to you prepaid you complete installation of the modified drive shaft and install control cable.
Another solution but no application for Nissan from this company. Anyone know of another company that makes these?
Remco's Lube Pump
When your vehicle with an automatic transmission is driven, the transmission is lubricated by an engine-driven transmission fluid pump. When the vehicle is towed, this engine-driven pump does not operate. Another means of lubrication is needed. REMCO'S Lube Pump was developed to provide a reliable lubrication system for the transmission while it is being towed. To tow your vehicle, connect the cable and turn on the switch on the monitor in the motorhome and you are ready to go.
1/8 HP self-priming diaphragm pump insures high volume lubrication.
Full volume selector valve directs oil for driving or towing.
Electronic monitor on motorhome dashboard safeguards the transmission
Easily transferred to any other approved vehicle.
One coiled electrical cable between the motorhome and car provides all the circuits for the pump, monitor, and towed vehicle tail lights.
All wiring and fluid connections for car and motorhome included.
Each make/model transmission tested for 20,000 miles before approved.
Easy installation by garage or weekend mechanic. Complete step-by-step installation instructions provided.
One year/10,000 miles limited warranty (warranty not applicable on transmissions with over 40,000 miles).
Don't See your application just give us a call
