1 - 8 of 8 Posts
Well, last Saturday I finally got a day to wrench on the X a bit. I have new shocks I wanted to put on the front and I wanted to remove the LCA so I can bend the mounts back into place. Needless to say, 3 of the 4 cam bolts are rusted to the bushing sleeve and will not come out.
I have tried PB Blaster, dead blow hammer, torch (though not a lot since the bushings are rubber), ball joint press and air chisel. They will not budge.
So, if the stuff I bought off Steve last year (LCA, etc...), ever gets here from CO (I am starting to doubt it ever will), I am going to be breaking out the sawz-all and just replacing the LCA's.
Oh, the reason the LCA's need to be replaced is because you can not just replace the bushings. Go figure, the LCA's are $150 each from the dealer.
So, if you live in a place where they use road salt in the winter, I would buy the Lifetime alignment from Firestone and remove the cam bolts on a yearly basis.
They don't look bent and I can't see a line between the bolt and the sleeve (it's all one ugly glob of rust).
I had the same thing happen to the Jeep. I since have replaced half the bolts on the suspension and will be doing the rest over the winter. Salt sucks.
This is one of the reasons I'm actually glad that my truck came without cam bolts and I needed to install them - plenty of anti-seize was part of the construction recipe. In fact, much of my suspension both front and rear has been re-assembled with anti-seize - ball joint shafts, lower strut/shock mounts, etc etc etc. On a brand-new truck, there were already bolts beginning to bind when I took them apart the first time.
1 - 8 of 8 Posts
