Any thoughts from you guys about which 2" lift is better. Trying to decide.
The Calmini shackles are steel, not aluminum.Erick said:If someone were to show me a Calmini shackle that has degraded to nothing because contact with the steel then I would accept that, BUT it's just a matter of hypothetical situations of massive friction.
No idea, I haven't got to that point yet because what I have works so well, But if they are good, I have Red Paint!d-rap said:MC, does your anti-blue thing extend even to King coilovers?
http://www.engineersedge.com/galvanic_capatability.htmusmc xterra said:[I cried for something that would stop the corrosion when aluminum and steel meet up.
Did I miss something? They explain the problems no real cures.dpatton said:http://www.engineersedge.com/galvanic_capatability.htmusmc xterra said:[I cried for something that would stop the corrosion when aluminum and steel meet up.
http://www.corrosion-doctors.org/Definitions/galvanic-series.htm
No, it was more pointing out why a "cure" isn't easy to findusmc xterra said:Did I miss something? They explain the problems no real cures.dpatton said:http://www.engineersedge.com/galvanic_capatability.htmusmc xterra said:[I cried for something that would stop the corrosion when aluminum and steel meet up.
