i have a 2007 xterra s 4x4 i was trying to install the calmini coil spacer lift. while i was removing the top nut i ran the strut cylinder all the way out and blew out the srut air and oil. I didnt hold the threaded portion at the top while removing the large nut.So now i have to replace the strut and cant get the bolt and nut loose on the lower control arm. Has anyone come across this? is it reverse thread? Since i am in alaska i have to wait five days for one from the dealer since the local auto parts stores do not have these struts. While i am at it is there any other tricks while doing this install? The calmini instructions suck!!
