1 - 19 of 19 Posts
· on line
Calculating Amperage
Formula: Power = Current x Voltage
Example:
85 watts (Power) = Current (Amperage) x 12 volts (Voltage)
85w/12v = Current (Amperage) x 12v/12v
7.08 = Amps
Here's a Handy Calculator to help with that.
Now that you know how many amps are on your circuit here's a 12 volt Wire Gauge vs. Amps Chart.
Feel free to let me know if there's any other useful tidbits to add.
Remember to be very careful with electrical installations! None of us want this:
· on line
This is a VERY handy list of formulas for converting from volts, amps, watts, and ohms. All you need to know is two values and you can find the third easily.
Now there are a few caveats: First, though we always think around 12 volts as a constant value, in fact it may be more conservative to assume 13.5 volts, which more likely what your charging system will be running at.
Second, you may measure a certain resistance (in ohms) with your multimeter, like for instance on a light bulb, but after current is flowing and the heat increases, then that resistance will greatly increase, especially on light bulb filiments.
· Registered
Printed that chart and used extensively during my off road light and Ham radio install. Very handy, almost thought about laminating a small card and tossing in tool box...hmmmmmm.
Thanks Oz...and all contributors!
Satisified NewX customer #1
· Registered
It may also be useful to keep in mind that you may have less than 12 volts under heavy load or just a weak battery.
If your voltage drops to 9 under load, that 85W example at the top becomes 85/9 = 9.4 amps. You could start blowing fuses if you run accessories with less than 12 volts.
All of your electric mods are fused, right? :)
· on line
Not exactly true....if you're running 9 VDC with the motor running, you've got problems that need to be addressed immediately.
General rule of thumb, vehicles run at 12.2 VDC with engine NOT running (battery power only). And 14.4 VDC with engine running.
· Registered
To clarify, my example refers to running accessories with the engine not running. As the battery drains, the voltage will drop. If I run a high drain accessory (like a winch) with the engine off, the voltage will drop quickly.
· Registered
Example:
7.08 = Amps
lol his rear wheel got stealthed naturally
· TNX Senior Administrator
ABQ, NM, USA
This a site, (www.circuitlab.com), is actually fairly decent for drawing out a diagram, if you feel so inclined.
  • Like
Reactions: brokefoot
1 - 19 of 19 Posts
