Hey guys, Im trying to get my arb locker installed for my c200k. The problem is my installer needs the shims for the pinion gear (regearing to 3.36) and he is concerned that the shims in the ARB kit are not enough for the install (which apparently can be a problem, as seen in other threads.) so those of you who have had a c200k installed. What was the remedy, or did you use aftermarket parts? The OEM parts don't come in a package of shims to add if you need. It appears to be one spacer of different lengths. For example 2.0 and the next is 2.05. To buy all the available shims is like $400. Not going to do that. Does any one have experience with this? These parts aren't available like for the m226.
