1 - 20 of 28 Posts
Vendor
If you have ever been on the trails pulling yourself back on your feet, you understand that the most important factor about tough situations is getting out of them faster. Winches are made for guys, who seem to always swerve towards the closest mud hole. We offer both hydraulic- and electric-powered winches in all sizes and designs to fill any winching need from 2,500 pounds of pulling power up to almost 20,000 pounds. Winches we sell are equipped with multiple gears that make the most out of each unit's ability and allow pulling at slower speeds when more control is needed or at faster speeds when rapid pulling is best. To learn more you can visit Winches section at CARiD.com.
Rugged Ridge® - Off Road Winch 8500 lbs http://www.carid.com/rugged-ridge-winches/rugged-ridge-winches-4430903.html
Features:
- Durable 5.5 HP series wound motor
- Tough 3-stage planetary gear box with 172.8:1 gear ratio
- Durable 12' all weather cable remote solenoid box
- HD steel cable winch includes 94' of 5/16" diameter wire rope and latched hook
- Performance synthetic rope winch includes 100' of 11/32" 12-strand braid synthetic rope with a breaking force of 16, 550 lbs.
Mile Marker® - Electric Winch 15000 lbs http://www.carid.com/mile-marker-winches/mile-marker-electric-winches-3621165.html
Features:
- 15,000 pound load rating
- 79 feet of 10-millimeter thick aircraft grade cable winding
- 5.5 horsepower
- Weighs only 101 pounds (25% lighter than competitors)
- 12-inch wired remote control allows operation from a safe distance
- 3-stage planetary gear set design
T-Max® - Performance Series Winch PEW-9500 http://www.carid.com/t-max-winches/t-max-performance-series-winch-437475.html
Features:
- Rated Line Pull: 9500 lbs Single Line
- 6.6 hp 12V Series Wound Motor
- Gear Ratio: 218:1
- Weight 77 Lbs
- Overall Dimensions (L x W x H) 21.2" x 6.3" x 8.6"
- Mounting Bolt Pattern: 10.00” ± 0.015” x 4.50” ± 0.010”
WARN® - 12000 lbs 12V DC ZEON™ 12 Electric Winch http://www.carid.com/warn-winches/warn-zeon-electric-winch-12515677.html
Features:
- 12,000 lb. single line pulling capacity
- Line speed: 30’ per minute under no load and 3.1’ per minute at 12,000 lb. max. load
- Fast and reliable 3-stage planetary gear train with 216:1 gear ratio
- Dimensions: Integrated configuration – 24.25”L x 7.15”D x 10.52”H, Low-profile configuration – 24.25”L x 7.15”D x 7.84”H
- Weight: 98 lbs.
Also you can check installation video here: How to install a winch featuring the WARN ZEON
What do you think about them?
Features:
- Weight: 98 lbs.
I must have missed the hundred pound winch. I'd kind of like to see that.
The Warn shown above in the op is 98 lbs. Rounding to 100lbs isn't a stretch.
My winch is 136lbs.
WOW!
Im shooting for under 50lbs
http://www.4wheelparts.com/Winches-Winch-Accessories/XRC-9-5K-Winch-Synthetic-Rope-Gen2-With-Aluminum-Fairlead.aspx?t_c=18&t_s=300&t_pt=100702&t_pn=S/B98495
Waterproofing: IP67 Rating
Fairlead: Hawse
Rated Line Pull: 9,500Lbs (4,309kgs) single-line
Remote Control: Included
Motor: 6.6hp Series Wound
Recommended Battery: 650CCA Minimum for Winching
Control: Remote Switch, 12’ (3.7m) lead
Battery Leads: 25mm, 72" (1.83m)
Gear Train: 3-Stage Planetary
Gear Ratio: 161.28:1
Finish: Textured Black
Weight: 46.0 lbs (20.9 k)
Clutch: Sliding Ring Gear Mounting
Bolt Pattern: 10.0 " x 4.5 "
Brake: Automatic In-Drum
Overall Dimensions (L x W x H): 22.3" x 5.4" x 9.4"
Drum Size: Diameter 2.5"
Cable type: Synthetic Rope
Cable: 98.5’ 3/8” Diameter
I have the ARB. Winch fits great and I have the control box mounted on the bumper so it's easy to reach and the clutch lever is easy to reach through the hole in the top of the bumper once you clock it 90 deg.
I know the ARB is not everyones taste so I don't want to hear any complaints from people about my choice for my truck. (not directed at you TN but I know there are some people who will bit#h about it as soon as you mention ARB bumper).
"Spydura" is a goofy brand name. But then again "Dyneema" isn't much better. Clearly "Amsteel" had the best PR department.
The weight difference you are talking about is a skid plate, 30lbs will not make a difference.
I have 2 XRC8s with steel cable and they run about 90 lbs each, btw I haven't had any issues with mine. For $300 (what I paid) they are a good winch so far.
Not sure why you're complaining when they are posting in their own vender thread about product they supply.
No, that's the one major flaw in the ARB. Because it's designed to work with the airbag system and crumple zones it doesn't have recovery points. You can still use the stock tow hook although I stongly sugest replacing it with something that doesn't stick down as far or you'd do what I did and bang it off a few rock in Moab and do some minor damage to it:
1 - 20 of 28 Posts
