1 - 11 of 11 Posts
Something (or someone) hit my bumper corner where there is a step.
136812
I am
I am unable to remove it to have a closer look behind. Looks like there are two plastic connections broken behind, and I am not sure if this is an integral part of the bumper?
136813
136815
Is there a way to remove this step part and reconnect or do I need a new complete bumper?
Midnight Blue 2007 X
That's sucks man... but it's easy to fix/changr that part. Few month back some one was nice to my side as well and broke it and left it all scratched ... but luckily after I painted my bumpers tou can't even tell
2015 Cayenne Red Xterra Pro-4X
View attachment 136812 I am
You might want to consider painting those bumpers while you are taking the time to fix it. :) No offense, just saying.
Its pretty easy to remove the entire corner. Just do that and see how bad the plastic clips are on the step. Here is a pic from when i did my lights so you can see what it looks like on the back side.
Sorry it doesnt show more of the step.
136832
pry up the cover on the flat step, it just snaps on. I recall a screw or 2 underneath, the rest is just gromets i believe.
It should just pry out
Thanks, I did pry out the flat step.
136865
136868
I do not see any screws under that. The left side seems to have broken of. I do not see any screws, when I do try to pry the whole thing off the bumper moves with it.
Are those plastic rivets that connects the step with the bumper? If so the only way is to brute force it by prying and hope the rivets break before the bumper breaks?
136866
136867
Thank you, so there are nuts on the inside holding the side step screws?
The red circles are the attachment screws for the side step?
136869
Yes, that is what is holding the step to the bumper corner. Quit prying on it, unless you want to replace more stuff. Just take it off and add a larger washer to the backside of the broken one. That should hold it firmly in place. There is a L bracket under the step for reference. Corner removal is easy. The biggest problem is the plastic clip above the L bracket. (In picture behind the light above L bracket, black plastic piece. ) Just be careful as that thing can break or break the clips holding on to it. Once you see how easy it is, then pop off the other and add some lights.
136871
I need to replace my rear left step cover. Here’s a photo of what it looks like without one if that’s helpful.
136880
1 - 11 of 11 Posts
