1 - 13 of 13 Posts
Don't the knock sensors kick in and retard the timing so it doesn't ping, even if you run a +2 advance?
yes, this should happen. its the engines way of protecting itself. but then the 2 degree advance was pointless if you just let the computer retard the timing.
you wont see any benefits unless you use 91 or higher octane
Discussion Starter · #10 ·
Thanks guys is their recommendations for setting this thing up performance wise or do you just set the 87 tune and call it a day got volant cai and soon to be ims its on its way
Im with lixterra i run +2 on 91/93 and when i run 89 I bump timing down to +1 . It pings on mine running +1-2 on 87 and worse when its warmer out .
1 - 13 of 13 Posts
