1 - 20 of 92 Posts
Username: BullDozerX
Model: Off Road
Year: 2005
Trans: 5 Speed Auto
  • Wade in-channel visors
  • KC 6" daylighters
  • Raingler Grab Handles
  • Running boards
  • Mud flaps
  • VHIDS 5000k Hi/Low kit
  • Nissan Keyless Entry pad
  • DEI Remote Start/Alarm
  • Rear Recovery Hitch Receiver
  • VisionX Tantrum Strobes (WHITE)*pending install
Suspension and Tires/Brakes:
  • Total Chaos Titan Upper Control Arm
  • SWAY-AWAY 2.5 Titan Swap Coilovers
  • Titan Inner/outer Tie Rods, Heimed Links ( to be installed soon)
  • Timbren front Bump stops (Removed, bolts rotted away...)
  • PRG Shim Kit
  • Bilstein 5100 series, Extended rear shocks (3-5")
  • 35" Cooper STT Radials
  • PRG Adj. Shackles
  • PreRunnerPartsAAL
  • Slotted Rotors/Green Stuff pads
  • NissanOnlineParts 2" Body Lift
Powertrain:
  • Volant CA
  • AC Snorkel ( Not installed )
  • BTF M226 ( Pending install)
Future Mods as Money Permits:
  • Custom 4" Rear Leaf pack
  • Custom Exhaust
  • Rear Tire Carrier
Lookin good man. Those tires are meaty. And I don't think it will ever be enough. I haven't really started on this truck yet but with my other cars in the past you always want more and more and more.
yeah man ditch the rear sway at LEAST...with that lift kit..you will most likely find that even the front removed is fine with radflo's.... just extra metal to get bent while wheeling...thats all it is to me.
Looking really really good there....BL is next! and u go to much more on the suspension lift yur gunna have severe UCA contact and a high CV angle. so either BL or drop bracket that bish! WOOT! :thumbup:
I remember when my parts were shiney....*sigh*
What all did you add? <- scratch that, question answered above
Looks good, I think. I'm putting my spacers and AALs on this weekend. Hope mine looks half as good as yours.
I'm sure it will man! I'm just glad I got the 3" inch spacer instead of the 2.
See, I didn't want to do UCAs and shocks if I could help it. A little out of my price range right now. Hoping 2" can tide me over until next year when I do full leaf packs, Radflos, UCAs, and rear shocks. Gotta stiffen everything up for the front and rear Shrock bumpers ;)
I'm think the same - I might go with a 2"BL to add to the 2" SL. I think at that point if I want to go higher it'll be a TS and 35" - waiting to see if the gearing LA Rana is waiting on materializes. It'd be hard to resist going with such a set up.
Looks good, a set of spacers will give you a good stance too.
1 - 20 of 92 Posts
