I don't know about the location or type of e-brake, but I do know about the how to:http://thenewx.org/phpbb2/viewtopic.php?t=2158
Yeah, very easy. What you want to do is to open the bleed valve then push them back. Although you can push them back without doing it, it can freak out the brake system. Since you have to bleed the brakes any way, it doesn't cause anymore work (just a bit more mess).kokopop said:Thanks for the tip. Were the pistons easily compressed with a old pad and a C-clamp?
