That's what I was afraid of. I'll probably just save up and pay to get it done. Thanks guys.kokopop said:From what I understand the biggest PITA with the AC BL is extending the steering shaft.
Can you post some pictures of your truck with the BL on?BoonDox said:OK since i have a 3 bl, i'll jump in here. Steering shaft was very easy
on my X. Second u don't have to drop the radiator, just remove the bottom 1/4 fan shroud. Presto saves u at least 2 hours... If u drop
u have to Dremel/ Cut the radiator brace. So the evaporator can stay in place.. :blackeye:
What size tires are you running in this pic?BoonDox said:![]()
05 with 2.5 sl & 3 bl
