1 - 5 of 5 Posts
I bought one today and I'm at a loss for where to mount it inside the eng. compartment. If anyone has done this...can you post some pics?
I have the non ground 6 fuse version. I have one on the firewall on the battery side and the other on the kick panel on the drivers side.
I have two breakers feeding them that I mounted to the top of the relay box.
Discussion Starter #4
MM
I bought the one with the - bus. I actually was able to move some OEM harness just enough to mount it on the firewall (in the engine compartment, battery side) Also mounted one of Blesea's single maxi fuseblock's ahead of the distribution fuseblock. I think in one of your posts elsewhere you mentioned a breaker in this position.
To mount the dist. fuseblock I needed to fab a standoff bracket for it.
PITA. Little room for this stuff on our trucks.
1 - 5 of 5 Posts
