1 - 20 of 585 Posts
Username: BlckHwk13
Year: 2006
Trim: X
Color: Midnight Blue
Disclaimer: I welcome all constructive criticism and I promise I won't cry and look for a moderator if you don't agree with what I do.
I also tried to list everything with a link to it so people won't have to ask me questions about everything on my truck. What a concept.
Suspension/Tires/Wheels:
- 4x 315/75/16 Goodyear MT/R Kevlars
- 1x 35x13.50R16 Mickey Thompson Baja Claw Radial
- 4x 16x7 Pathfinder wheels Bedlinded
- 1x 16x7 "S" model wheels
- Titan swap utilizing all new parts
- Moog inner and outer tie rod ends
- Moog camber bolt kit
- OME Lift Struts 607 springs
- PRG 2” variable height shackles Set at 2”
- PRG 2” spacers Currently 1" spacers now.
- Bilstein 5125 series rear shocks 3-5” Lift. Lower mounts raised 2”
- AALs
- (2) Spicer Life Series 1310 U-joints
- (2) Spicer Life Series 1330 U-joint
Powertrain/Drivetrain:
- M205 out of 2004 Nissan Titan
-Superior 4.10 gear set and master install kit
-Ford 8.8 out of 2005 Ford Crown Victoria 3.25” tubes! Narrowed to 68” WMS to WMS
- Ford Racing 4.10 gear set and master install kit
- Ratech Mfg Solid Pinion Spacer
- Billet Big Bearing Ford Torino Ends. Utilizes Inner Axle Shaft Seals
- Custom Dutchman 31 Spline Chromoly Semi-Float Axle Shafts with 6x4.5 Bolt Pattern
- Ford Explorer Rear Disc blanks. Milled for 6x4.5 bolt pattern. Thanks Kurt!
-Explorer Rear Disc Backing Plates, Brackets, and Calipers
- Ruffstuff 8.8 cover
-Ruffstuff Spring Under Swap Kit 60mm springs
- Custom 1330 U-joint driveshaft 3” OD .120 wall 30-3/8” Center to Center
- Diff breather extension
- Radiator bypass
- Volant CAI
- Replaced Throttle Body
- Replaced 02 Sensors
- Replaced Engine at 100,000
- Replaced 6 Injectors
- Replaced several Alternators
Interior/Storage:
- WeatherTech Digital Fit Floorliners (front and rear)
- Contico SUV Tuffbin
Electrical:
- 1x 30” Trail Worthy Fab LED light bar
- 2x Hella 500FF lights converted to 3000k HID
- 2x Rear roof lights
- 5 OTRATTW Switches
- Cobra CB
- 5’ Firestik CB antenna
- Cut front fenders
- 2” body lift
- WeatherTech Side Window Deflectors (front and rear dark tinted)
- WeatherTech RackSack
- WeatherTech PlateFrames
- Bedlined front bumper and grille
- Bedlined Hood
- Bedlined Rocker Panels
- Xoskel Lo Pro Light Cage
- Xoskel rear Lo Pro Lightbar
- Decals
- 16" Rear Wiper Blade
- AirFlow Snorkel via Group Buy
Armour:
- Modified TAG front bumper for 2” body lift
- Shrockworks Sliders raised 2” and tapped for OBA
- Custom BuckChetta Rear Bumper with Tire Carrier, Flag Mount, and CB Mount
- Skid Plates
Recover/Safety/Camping Gear:
- Engo 10k Winch with Synthetic Line
- 48” Hi Lift Jack
- 4x D-ring shackles
- Random safety gear
- Shovel (Roof mount coming soon!)
- Window screen
- Tow Strap
Of course more mods are in store... Now enjoy a few less interesting pics:
New spiffy black WeatherTech Floorliners
1.
2.
3.
4.
Proud Member of Great Lakes Xterras
About time, I was curious as to what you had done to your Rig after seeing shots from the Shocker Run. Looks Great. hopefully I can get back into the modding my Adventuremobile.
Lookin good girl
Shnazzy truck maam.... nasty color though ;)
Props on making the X tough.
BTW - you need skids and sliders.
Discussion Starter · #20 ·
1 - 20 of 585 Posts
