I know, same happened here. :whax:kokopop said:Anyone running BP Skids with the Shrock Gas Tank Skid?
I just tried to install the Shrock Gas skid and the BP T/C skid gets in the way of the front lip of the gas skid.
I need to take the grinder to the T/C Skid. Ugh!!!
You mean the bolt that holds the front drivers side of the skid to the frame? Mine too! I ripped it out when I ripped the stock tank skid off. I have not fixed mine yet, but my plan is to cut a very smal slot in the frame and using the shock trick of welded nut on a wire, feeding a new nut down into the frame. I have been running around with zip ties holding the skid up...it's worked so far.kokopop said:Top it off the frame bolt for the shrock skid is gone. So I have to tap it.
Nope, just loose the T/C skid, slide the gas tank skid lip under the T/C skid, bolt the gas tank skid and tighten the T/C skid. It's a tight fit.kokopop said:Did you end up cutting it?
