Tomorrow I'm bringing my truck in to have the OEM front shocks and coilovers swapped with some used Pro4x ones I bought here from a forum member. Normally I do this stuff myself but I didn't want to mess with coils, so I'm bringing it in.
From what I've read, if they do everything exactly as the OEM I'll have a "clunking" problem. From another thread;
"Let me tell you....I put new HD bilsteins on my S couple weeks ago, I had the nasty annoying clunk myself on BOTH sides....A friend on this forum gave me the fix as he had the same problem....stock shocks use only 1 washer ...u need to use 2...1 from old shocks and 1 from new bilsteins. one between the top of the dust boot and bushing....and other on top of perch under the top nut. Believe it or not...this WILL fix the clunk."
I bought these used and they didn't come with instructions or any other parts, just the shock and coil. Will I be missing the additional Bilstein supplied washer? If so, what size is it and can I get it from a hardware store?
Thanks!
Thanks!
