1 - 4 of 4 Posts
Battery was dead and trying to recharge it via jumper as for now driver door only unlocking automatically others are not responding....
Service garage recommended replacing BCM… Are there any tests to perform to check door lock operation, any tips how to confirm if automatic lock/unlock function is ON/ OFF. Appreciate for any comments.
So even by hitting the switch on the door only the driver door is responding?
Sounds like the cables may have been reversed....
You are charging the battery with jumper cables? Is the alternator bad and unable to charge it? Vehicles do weird things when the batteries are very low, get the battery/ charging issue resolved and see how it works.
Also try unhooking the battery and let the BCM reset. Low voltage dips do really weird things to electronics.
1 - 4 of 4 Posts
