I have a 2010 OR, 6MT with 120k on it. I don't use it a lot, hence the relatively low miles. I installed 4 new Cooper Discovery AT3 tires about 5 years and 5k miles ago, and ever since I've had a vibrating steering wheel, even after multiple re-balances. They say it's out of balance, and supposedly correct it, but it never gets any better on the road. The shimmy is barely noticeable at 55 - 60, but soon after hitting 60 - 65 it comes in with a vengeance, shaking the steering wheel about 1-1/2" so that I either have to speed up to above 75 or so, or drop down around 60 to mostly eliminate it. I don't really notice or feel it in my seat or the rest of the truck, just the vibrating steering wheel at certain speeds. It did it before I installed new tires, but I thought that it was a tire issue since they were pretty worn and mismatched (I had just purchased it).
So the question is, what do I look for? I've checked calipers (brakes don't drag and it stops straight and true), the ball joints and tie rods are good without any play, the wheels turn smoothly and freely without play so I don't think there are any bearing issues, so I'm at a loss. I've read a lot about drive shaft u-joints, and I'm close to going ahead and replacing all 3 of them, all though they all look good and don't have any play and aren't squeaking. However, in reading the various threads, it seems that most u-joint issues cause the entire truck to shake, not just the steering wheel, so wondering if I should try checking something else first?
I should add that while the tires aren't wearing unevenly, I probably need an alignment, or at least getting the steering angle sensor reset/recalibrated since the VDC and Slip lights are always on and never go out. Reading elsewhere that means getting the alignment checked and having these sensors reset and the faults cleared (or something like that, going from memory). Is it possible that this could be causing an issue?
Or did I possibly get a bad tire or something? Maybe I should take it somewhere else to try to get the tires balanced. I have a Big-O, Discount Tire, Pep Boys and a Firestone store near me for balancing. Are any of these any good for alignments or am I better off taking it to the stealership, which is a lot further for the alignment? Big O says that they can reset the sensors, but I'm not sure if their systems are trustworthy, for alignments.
I should have dealt with it a long time ago, but due to limited usage, mostly at lower speeds, I've just let it go, so too late to take them back and ask for other tires. I'm an experienced mechanic, so changing the u-joints isn't an issue, just not sure that'll even fix it.
