1 - 20 of 20 Posts
Well awoke this morning to find the passenger side floormat wet, smelled of coolant...not happy, kinda bummed my X is turning into a money pit
Sorry to hear that man, I wonder what would have caused that to happen? seem to me like it would have happened while the truck was on / driving. not while parked...
That would be my guess as well, not sure as to the how, no crazy driving, no off-roading just an up and down the HWY...
Trying to talk myself off a ledge...
Discussion Starter #4
Well damn...the more I read the closer to the edge I get, this look to be huge job...all I wanted to do was put my new air horn in....
I did not see any how to on this either
FYI- You can bypass it at the firewall until whenever.
Sucks. And I feel for you. It’s a time consuming job to fix.
I’m not advocating stop-leak in any way shape or form.....but.....it is an option to try. A bandaid at best, with possible consequences....but....it is an option. Choose wisely.
I’m surprised as hell it happened to a 2010! :-(
@MeHere! I did some google foo and came up with this tidbit about putting stop-leak through the core. It’s actually pretty damn smart, keeps it out of the radiator and hoses.
(If mine ever leaks I’m doing this first.)
https://www.thenewx.org/forum/11-powertrain-driveline/163602-anyone-done-heater-core-taken-dash-out.html
I put “heater core site:thenewx.org” into google. Many more hits. Didn’t see any direct how-to’s in my quick gloss over, but I’m sure there are several on tearing the dash apart. That’s the gist of it really.... lots and lots of tear-down.
Discussion Starter #7
I think I'll go with the bypass for now, is this only an issue when I run the heat or is it going to leak regardless?
Discussion Starter #8
I am now trying to turn this into a positive...I have a new air horn, a back up cam and a volt meter I want to hook up...
I'll do the bypass, get everything else ready and just make a big weekend outta it
It’s an open loop. It’ll leak if pressurized. Meaning, yes, it’ll always leak.
Bypassing it eliminates the pass-through of coolant, thereby the leak.
Give some thought to the localized stop-leak fix. I bet it’ll work. And much much less headache than tearing into the whole dash. (Just my 2 pennies.)
No matter your choice of fix, I wish you the best.
Don’t let this kill your dreams. Parts fail. It’s their job to do that. Regardless of make or model! The Disco I had a few years ago was constantly giving me fits, but man, did I love it. And I love the X even more!
Discussion Starter #10
Bypassing it eliminates the pass through of coolant, thereby the leak.
I have read some good reviews on Fiber Lock, I may do some more research on that brand
I am now way back from the ledge...my wife's voice "how mcuh?" was pushing me, lol
I still love my X
It will likely leak continuously until you route the coolant around it. There's a guy on here @Adam12SD who had the same issue recently and replaced the leaking factory heater core, it turns out that Nissan used a design where the pipe you connect to in the engine bay isn't a solid pipe all the way to the core. It has a connection that uses an o-ring, eventually they all will probably leak thanks to that. Good news is the aftermarket replacements use a solid pipe. He posted pics in the what have you done for your x lately thread starting on page 706
Discussion Starter #12
Awesome, Ill check the post!
Discussion Starter #14
Some of the work...the major issue was the original HC had quick connects about on the inside section, the replacement HC did not, had to pull the whole A unit up and back to get the new one in, plus I broke a piece to the pipe on in the engine bay trying to remove the tube from the pipe
When getting in there did you see the source of your leak?
And major kudos for having the balls to do it yourself. It’s a daunting task, as you now know!
Discussion Starter #16
Yeah the leak was right at where the heater core piper enter to heater core, the kinda flattened out section...
I was kinda bummed there was not a hot to on this, but after having done the work I am glad there was not as it probably would have scared me off! lol
Other than a teardown of the engine, I’d say this is the worst. It’s unbuilding and rebuilding the entire dash.
I’m hoping my 2010 loves me enough..... lol.
Discussion Starter #18
Once the job gets finished today, replacing the part I broke... that willleave me know with the task of cleaning the floors, what the hell can I do with the removal of the coolant smell? Awaiting the scary response "remove the carpet"
Remove the carpet haha. BUT, just because Nissan installed it as a single piece doesn't mean that you have to do the same. I'd pull the passenger seat and strategically cut it where it can't be seen to remove that section.
I've been really happy with the results of the spot cleaner I bought. It did a heck of a job on stains, dunno how it might work on removing your smell though...
I don't know if they still carry the specific model I bought, but it gives you and idea anyhow.
https://www.bissell.com/spotclean-proheat-pet-portable-carpet-cleaner-6119w
1 - 20 of 20 Posts
