1 - 12 of 12 Posts
07 Nissan Xterra
So I bought my first Xterra! I love it. I live in the NC/TN mountains and purchased it down toward Charlotte NC. On the way home I ran it a little hard coming up the Mountain and when I got to the top it slipped in the shifting a few times. (Never has it bothered again). I took it to three different mechanics who checked the fluid and felt like it was nothing serious, but each felt like the fluid should be changed along with the filter. So I did that fluid was old but not SMOD. All works well!
Then I joined this forum and the first thing I learned about was SMOD and I am a bit obsessive so I went ahead and ordered a new CFS radiator and started tearing into it this morning and realized someone else already fixed it! There is an external transmission cooler and the lines run back to the transmission. The two lines that run out of the bottom of the radiator have been plugged off. So now I have freshly changed the transmission fluid and I checked the radiator fluid and it is clean. YAY! Right?
I agree put your aftermarket in and rerun your trans lines they bottom of radiator. Fluid to fluid is better. And I’ve seen trans over heat with the bypass and added cooler also the air to fluid just don’t cut it if you tow a lot of off-road
still doesn't really address why it "slipped a few times" at the top of the mountain. unless what you experienced was it going into limp mode after overheating.
While you’re replacing the radiator you should also replace the two plastic input fittings in front of the firewall passenger side. If they haven’t been replaced already, they’re probably brittle and ready to go. When my one blew, I ordered the other one and it crumbled in my hand.
2011 PRO-4X
For the one closest to the fender you don't need anything. Just remove the plastic fitting and short hose and connect the long hose directly to the heater core.
For the actual "Tee" that goes bad Dorman makes an all aluminum replacement and is cheapest on Rock Auto. Don't do the brass tee method as the tee is difficult to find and when you buy everything it is the same pride as the complete Dorman one.
2005 Nissan Xterra OR
I need to do this sooner than later, I'm on borrowed time with that Tee. I looked for that aluminum dorman part but couldn't find it... Could you link it if possible?
1 - 12 of 12 Posts
