1 - 20 of 29 Posts
I just purchased these, but wanted to make sure they are the right ones before I put them on. Here's the part no. 9.9101 G. I have seen the other threads about this but it had a "C" on the end, I wonder if I can go with what I have or do I need to take them back
show us a pic?
thye look like they'll fit and do the job. If they ride too high (impact too early), cut off the first level..
Im gonna save my cash and go for the timbrens. After seeing how much abuse they can hold up to without wear and tear, I can justify paying the big bucks for them.
Discussion Starter · #14 ·
does anyone know the size of the sockets I need???? I'm sitting in the sears parking lot and typing this form my blackberry. HELP!!
Now wait! You can view this site from your blackberry?
im helping the best i can
Read Only
willgr1 said:
you'll also have to drill the hole out a little more to get the new bolt in...
When I installed these, I didn't use a drill. I just took a tap and hand turned it in. Didn't have to jack up the truck to get clearance for the drill. When I swapped to the Timbrens, the hole was the right size.
Original bump stop nuts are 12mm. The Energy Suspension nuts are 9/16.
1 - 20 of 29 Posts
