1 - 20 of 29 Posts
For those of you that changed out your transmission screen ("filter"), did you use a Nissan part, or an aftermarket one?
The reason I ask is because the one I got from AutoZone doesn't look anything like the factory screen, so I didn't change it out. Instead I just cleaned the pan magnets and reinstalled with the original gasket. No leaks so far.
Pic of tranny with factory screen:
Pic of aftermarket screen:
Pic of cleaned pan magnets:
what's the part number for the 2nd gen screen? I looked and looked at courtesy and could not find one listed. Almost as if it's part of the tranny..
so i guess that would be a $4000 filter? ;-) Buy the whole tranny for it.
do you have to clean it to make it to the higher mileages?
personally, i didn't think undoing all those bolts that hold it in and re-installing was worth it. I really think there is more risk in dropping and cleaning it then leaving it alone, though i do not speak from any experience or knowledge concerning it, just by looking at it and hearing that the o-ring may leak air which will cause tranny issues.
with that said, I am seriously considering installing an inline filter but need to do more research. I do not want to introduce particles from the filter into the tranny obviously so it needs to be a filter that will not do that and of very high quality.
would be nice to have a clear one of there was such a thing, that way you could see your fluid color and status of the filter.
Only reason I dropped the pan on my wife's XJ was because it leaked. It was a huge pain in the A$$ to get it all back together again. So far, no leaks though.
1 - 20 of 29 Posts
