tech sheet as promised:
Year: 2005-07
This Database Was Last Updated On: 7/3/2007
Index #: 4610
Alarm
Constant 12 volts GREEN IGNITION SWITCH HARNESS
Ignition 12 volts WHITE/GREEN IGNITION SWITCH HARNESS
Starter GRAY IGNITION SWITCH HARNESS
Dome Light BROWN (-) AT BCM PIN 63 ** *
Trunk Pin Switch YELLOW (-) DRIVER KICK OR BCM PIN 43 **
Parking Lamp GRAY (+) DRIVER KICK, HARNESS TO REAR
Power Lock VIOLET BCM PIN 45 ** #201
Power Unlock LT GREEN BCM PIN 46 **
* DOOR PINS WIRES: LF GRAY Pin 47, RF LT GREEN Pin 12, LR PINK Pin 48, RR BLUE Pin 13. All Wires Are Found At The BCM ** The BCM (Body Control Mouule) Is Located To The Right Of The Steering Column. #201- See Negative Pulse Door Lock Diagram
Click Here For Our Databus & Immobilizer Bypass Cross Reference
View Diagrams
Accessories
Window Up D\GRN/RED P\PINK D\RED P\YELLOW IN DR DOOR #211
Window Down F/GRN/WHT F/L BLUE R/L GREEN R/PINK AT SWITCH
Ign Key Warn BLACK (+) IGNITION HARNESS OR BCM PIN 37
Trunk Release SAME AS DOOR MOTORS
OEM Horn BROWN (-) AT STEERING COLUMN
Headlights PINK DR AND RED FOR PASSENGERS AT IPDM *
OEM Alarm Arm LT BLUE (-) DRIVER KICK OR BCM PIN 8 **
OEM Alarm Disarm RED/WHITE TO GRAY (-) DRIVER KICK OR BCM PIN 7 **
#211- See Reversal Rest At Ground Power Window Circuit Diagram. * IPDM (INTELLIGENT POWER DISTRIBUTION MODULE) Located In The Engine Room **BCM Located To Right Of Column Behind Driver Dash
View Diagrams
Remote Start
Tach Signal NOT WHITE/GREEN ANY FUEL INJECTOR #239
Ignition #2 RED IGNITION SWITCH HARNESS *
Ignition #3
Accessory GREEN/YELLOW IGNITION SWITCH HARNESS
Neutral Safety
Brake Light YELLOW (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L BLUE (+) AT HARNESS TO REAR IN DRIVERS KICK
Rear Window Defrost YELLOW (-) IN 40 PIN WHITE CONN AT BCM **
* Cold Start Wire- LT GREEN At Ignition Switch Harness ** BCM Located To Right Of Column Behind Driver Dash #239- See Immobilizer Bypass Diagram
View Diagrams
InterConnect Harnesses
Function Part# Avail Location
StrInt,+12,Gnd,Ign no
Horn Honk no
Lock & Unlock no
Light Flash no
Dome Light no
Trunk Switch no
AL-100 / VIP-4000 no
Remote Start no
*Click on a part number above to see a picture of the harness location*
View Diagrams
AL 100 / ULTIMATE
RKE Module BEHIND PASSENGERS SIDE DASH
Motor Lock PURPLE AT BCM PIN 65 *
Motor Unlock BLUE AT BCM PIN 66 *
Drv Door Unlock GRAY AT BCM PIN 59 *
OEM Relays BUILT INTO BCM *
Addon Security Type #5 CONNECTION #225
#225 See AL-100/VIP-4000 Type 5 Diagram * BCM Located To Right Of Column Behind Driver Dash
View Diagrams
Tech Notes
Driver Passenger Size Location
BLUE (+) L GREEN Front
BROWN (-) RED
GREEN (+) GRAY Rear
BLACK (-) ORANGE
