1 - 5 of 5 Posts
I want to make sure if they are,i want to upgrade the suspenssion in 2wd xterra along bilstein shockw and struts i've received already.
Thanks
Stronger, no.
Slightly taller, probably. The 4WD does sit a little taller then your 2WD even after you factor in the tire size. Something like ½".
I have been thinking of trying a set of 2WD front springs to add a little unloaded rake and level it when loaded, without the un-needed height gain of lifting the rear.
1 - 5 of 5 Posts
