Yupp - It is I with the Diff skid. I will go outside now with my new Digi SLR and take some pics of the redesign for ya'll.
It's held on by the 2 U-bolts, plus a bar that goes over the top of the front of the diff, hense it will not rotate anywhere and become an earth mover. Tried and Tested off road last weekend. No rattle on the Gas Tank skid and no rubbing on the gas tank - Which the original design did until I sent the original back and AC redesigned it. If you want diff armor for the D44 armor and can't wait 6 months for it - This is the only option. I personally am happy with it.
Looking at these pics. Looks like I mounted it a little off center! lol. Will have to losten the bolts and move it over a little, so it's more centered.
Difficult to get a pic of the bar that loops over the front. Basically there are 2 uprights welded to the front of the skid, with a metal bar that bolts over the top. It was said metal bar that was originally rubbing on the gas tank, but they made the 2 uprights alot narrower now, so there is a ton of clearance from the Gas Tank, even tho I appear to accidently have mounted it closer to the Gas tank.
I wanted armor A.S.A.P because the first trip I took my X off road I hit the diff and peeled back the bottom of the cover. Causing a leak, so had to pull the cover and re-seal it, which wasn't fun as the first time I did it I didn't use enough liquid gasket and it ended up not sealing properly. 2nd time was a charm tho.
