Hey, Has anyone changed their fluid in their MT? How about the T-Case? Any special gaskets needed?
K kokopop · on line Joined Feb 8, 2006 · 2,938 Posts Discussion Starter • #1 • May 8, 2007 Hey, Has anyone changed their fluid in their MT? How about the T-Case? Any special gaskets needed?
M Muzikman · on line Joined Jan 29, 2006 · 15,651 Posts #2 • May 8, 2007 For the TC you need drain/fill plug washers.
K kokopop · on line Joined Feb 8, 2006 · 2,938 Posts Discussion Starter • #3 • May 8, 2007 Time to contact Turnersville Nissan!
K kokopop · on line Joined Feb 8, 2006 · 2,938 Posts Discussion Starter • #4 • May 8, 2007 Muzikman said: For the TC you need drain/fill plug washers. Click to expand... Dexron 3?
M Muzikman · on line Joined Jan 29, 2006 · 15,651 Posts #5 • May 8, 2007 I am in a Citrix class right now, so I can't look it up in the service manual. I can't remember.
K kokopop · on line Joined Feb 8, 2006 · 2,938 Posts Discussion Starter • #6 • May 8, 2007 Muzikman said: I am in a Citrix class right now, so I can't look it up in the service manual. I can't remember. Click to expand... Cool. I just looked it up. Dexron 3 or Mercon. Spent yesterday battling with a TS server. I lost because the client was trying to have 12 users access thru TS to a network drive on an XP box. XP limits the # of connections to 10.
Z ZwithanX · on line Joined Jul 18, 2006 · 142 Posts #7 • May 12, 2007 Any luck with this Koko? I want to change the oil in my 6sp. too. Take pix if you can! Z.
