First and foremost i would like to thank Greg for guiding me through the install over the phone even on his day off (can you say customer service) and sexterraPA for his step by step instructions. You guys rock!! Thanks also who chimed in when i needed help.
OK. The lift started late Sat afternoon and ended late Sun afternoon. Most of it was fairly easy except for trying to fit those Radflo washers and spacers in the shock mount and cutting the UCA bolt. The only thing about the rear was trying to get the passenger side shackle off. I found it easier to remove the last exhaust hanger so the shackle has more room to come off.
All i can say is the ride and stance are a night and day difference from stock. The ride is much better even though the front is stiffer. I thought my wife was going to trip out cause of the height but after going for a test drive she commented on how the rear doesnt bottom out anymore. I do have a slight vibration at around 35-40mph and again at around 80ish. Not too bad but i think ill get the shims just in case my wife complains since she drives it on weekdays to work. NO alignment issues so far and my steering wheel is straight and true. Im still gonna get the alignment done though. Well enough yapping, here are the pics. Oh yeah, at full flex, the brake lines are still cool so no need for them.
Here is my pinion angle. How does it look?
