41 - 50 of 50 Posts
That same kit is arriving this week via FedEx, except I went with the medium coil springs as my truck is essentially stock. I hope to find time to install it by next week and will take pix and measurements. Chad and Steve at ADO were incredibly helpful in finding a kit that met my needs
Pete
Could you please advise the package weight and dimensions?
2010 Xterra S
@ataha1184 - three packages. Two were leaf springs with FedEx labels taped to them. Each was 48#. First to arrive was a box about 9x9x42 inches weighing about 50#. It contained the shocks, struts, coil over springs, and SPC camber bolts.
I placed an order for the Radflo Kit with the Broverland leaf pack last Friday from AllDogsOffRoad, unfortunately there is a six week lead time as Radflo is currently backed up and the coilovers are made to order :(.
I'm debating whether I should try the install myself or have my mechanic do it, I'm more inclined to following Ry's suspension kit video and do it myself. I will also be replacing the lower control arms as I already know the right side is seized and will have to be cut out.
Congrats on the purchase, now to test your patience! I think you should install yourself. The lift install will probably be easier than the LCAs, and especially so if you end up cutting on them.
Thanks! I was told there's about a six week delay with the Radflos from Radflo themselves. I'm hoping it isn't too cold by the time I receive everything, I live in NJ and six weeks put me at mid November+. If I do end up doing it I'd be working on my driveway.
I think I'm going to pull the trigger on this lift kit this week. My 06 has 200k on it. Should i order the UCAs and anything else i should be replacing while I'm installing this lift?
2010 Xterra S
If the OEM parts need replacing, sure. But if they are in good shape I'd not spend the extra cash. The Alldog kit gives about a 2" lift, just short enough to not require a bucket of costly mods.
I went with the 5100s (paid to have the coilover springs installed so I could bolt them up myself), the BROverland leaf pack, and the eccentric camber bolts. It didn't come with shims but when I reported vibration between 30-40mph Alldog sent them for free. For my style of driving on our badly maintained roads (75% of them dirt) this kit is ideal. Serious offroaders might have a different opinion
41 - 50 of 50 Posts
