Searched extensively when I did the lift and stumbled across a link to recommended Frontier specs, can't seem to find it now.
Here's my problem:
I have a 2" spacer lift on the front of my truck. Was just airing up the tires, and the wheel happened to be turned pretty sharp. I noticed that I have more where along the outside of my tire, both R and L, compared to the inside.
EDIT FOR ACTUAL PICS:
Overall Right Front Tire:
Outside edge:
Inner Edge:
Uneven Wear Pattern (note the high lugs):
Any ideas? I have probably 5k on the setup since i installed the spacers in June, had an alignment the next day and everything was within spec. I suppose i could have knocked something loose....
Here's my problem:
Outside edge:
Inner Edge:
