Ok so I took the X to the local Firestone service center after putting on the lift to have the alignment set. When I picked up the truck they had this pretty little print out with some numbers correlating to the L/R camber, caster and toe. Now I dont know the first thing about aligning a vehicle but when I saw 3 of 4 numbers were highlighted for camber and caster I asked if that meant those numbers were outside of factory specs and they guy said yes. What bothers me is what he said next... He said that the camber and caster COULD NOT be adjusted on my vehicle and that they could only set the toe. Are you freaking kidding me? I have what I thought were the camber adjustment bolts as my X is an early '05 model. Am I once again falling victim to piss poor service in the DC area? AAAGGGHHH!!!!! :banghead:
