Intro Comments: Hello everyone. This is the build thread for my Xterra. This is my first foray into a 4-wheeled off-roading vehicle. Gas sucks on this so I'll primarily be using it for weekend trips & off-road expeditions and do pretty much all other driving/commuting on my bike.
I want to build my X to be a capable off-roader and vacation rig minus the 2000lbs of extra weight I see on some trucks here that has the potential to bog me down on trails, break the drivetrain, and reduce my MPG to even worse than it already is. I do not want a titan swap because I want the ability to do tighter trails. This should make the FleXterra very functional without being too much to handle.
(12/14/2016) EDIT: LOL LOOKS LIKE I'M TITAN SWAPPING - THAT WAS SHORT LIVED. But seriously. Maybe I'll keep 33" tires. No need for 35s... right?
(11/5/2018) EDIT: Yep... 35's. I should have known. What's next, levitation?
Username: AlbatrossCafe
Xterra Name: Yoshi
Year: 2011
Trim: Pro-4X Titan-swapped
Color: Metallic Green (or 'Diarrhea Green' depending on the dirt level)
Transmission: 5 Speed AT
Mileage: May 2016 (My purchase date) - 54,382 miles
Packages: Rockford Fosgate Audio, Leather PRO-4X Seats, PRO-4X Carpet Mats
Legend:
[+] = Done
[-] = In progress
[ ] = Want
[x] = Removed/destroyed
------ MODS ------
Titan Swap List:
[+] 2012 M205 Nissan Armada Front Differential with 3.36 gears (bought with 57k miles)
[+] Titan-length Radflo 2.5 coilovers powdercoated ORANGE
[+] SPC Titan Forged Upper Control Arms
[+] Moog Titan Lower Control Arms
[+] Moog Titan Inner/Outer Tie Rod Ends
[+] Cardone Titan Half-shaft CV assemblies with Heavy Duty boots
[+] Stainless steel titan-length front brake lines
Suspension/Lift:
Basically I HAD this kit but with an Alcan Custom Leaf Pack.
[x] Front Coilovers/Shocks: PRG Radflo 2.0 Coilovers with 650# Spring Rate (3" lift)
[x] Front Coilovers/Shocks: 14mm NON-STEPPED bolt for lower shock mount so that it doesn't clunk all day
[x] Front UCAs: SPC Upper Control Arms
[x] Front: 1" Nisstec Spacers with extended studs
[x] Rear Shocks: PRG Radflo 2.0 rear shocks 0-3" lift (21.5" eyelet to eyelet)
[x] Rear: Stock Shackles (cut because they fit like garbage with Alcans)
[x] Rear Leaves: Alcan 3" full-leaf pack replacement with 250-350lb extra weight
[+] Rear Leaves: Alcan 4" full-leaf pack replacement with 500lb extra weight
[+] Rear Shocks: Radflo 2.0 rear shocks 3-4" lift
[+] Rear: Nisstec 1" bump stop extensions
[+] Rear: Longer U-bolts & U-bolt flip kit
[+] Rear: 3-degree PRG billet aluminum shims
[+] Rear: PRG Adjustable Shackles set at first hole (1" of lift)
[+] Front: PRG Cam bolts
[+] 1" Nisstec Body Lift
[+] Wheelers Front Superbump Bumpstop mounted on the bash plate
[+]Trimben Active Off-road rear bumpstops
Wheels/Tires:
[x] 285/75/R16 MasterCraft Courser MXT
[x] BORA 1.5" Wheel Spacers
[+] 315/75/R16 Mickey Thompson Baja ATZ P3's
[+] BORA 2" Wheel Spacers in the rear
[x] 2011 PRO-4x Custom painted wheels
[+] 2015 "S" custom painted wheels
Engine/Exhaust/Drivetrain:
[+] Intake Manifold Spacer
[+] Airflow Snorkel
[+] Rear differential breather valve relocate
[+] M205 ARB Front Locker
[+] RuggedRocks 4.10 gears
[+] Hardcore Offroad Front Bumper with full guard
[x] Shrockworks tire-carrier rear bumper
[+] MaxGear Extended Swingarm rear bumper
[x] BTF Differential Cover
[+] ARB M226 Diff cover
[x] Stock PRO-4x skids
[+] White Knuckle Rock sliders with rear diamond top plate
[+] Rear Shock Skids
[+] Hefty Fabworks Aluminum Skids (full set minus rad skid)
[+] DepHep Roof Rack with rear storage extension & expanded metal floor (10% of sale <3)
[+] Raingler cargo net for DepHep rack with orange stitching
[x] Remove OEM "mudflaps"
[x] Remove OEM sidestep rails
[+] OEM Bug Deflector
[+] "Nissan" badge off a 1986 truck
[+] Soft rubber mudflaps on front & rear
[+] ARB 2000 Awning with side wind-break
[+] Weathertech rubber mat on front driver area only (lol)
[+] Raingler Hybrid Ceiling Net with orange stitching
[+] Auto-dimming, compass, AND temperature Gentex mirror swap
[ ] Inclinometer
[+] Custom driver's side window no-drill molle panel
Recovery/Comms:
[x] 48" Hi-lift jack (dad bought Circa 2001) & Roof Mount (removed because carrying/using is too cumbersome)
[+] Powerbuilt 3-ton Jack + jackstand combo
[+] 20' Generic ~15,000lb Tow Strap
[+] ARB 30' 24,000lb Snatch Strap
[+] ARB 20,000lb Snatch Block
[+] Smittybilt 40,000lb 8' tree saver
[+] Smittybilt X20 10k Winch with Synthetic Line
[+] 350A continues, 600A intermittent battery cutoff switch with 12" 2 AWG cable to cutoff winch power (to prevent phantom spooling)
[+] QUAD ORANGE SHACKLES
[+] Midland 75-822 CB Radio
[+] Firestik II with HD Spring and universal mount with stainless-steel U-clamp
[+] Bigfoot 38,000lb Soft Shackle
Lighting/Electronics:
[+] HID Homemade Headlight Conversion (Morimoto Kit)
[+]Odyssey Extreme Series 34-PC1500T Battery
[+]Zheking Battery Tie-Down
[+] Diode Dynamics Luxeon LED Fog Lights
[+] Thrunite TC10 V2 RECHARABLE flashlight mounted inside of driver's door with quickfist
Other:
[+] 4-pin trailer wire harness welded to the inside of rear bumper
[+] Trasharoo (Tan)
[x] VIAIR 300p Portable Compressor (this thing is GREAT)
[+] CKMA12 ARB Onboard Air Compressor with tire fill-up kit
[+] Spare key safe
[+]Staun Automatic Tire Deflators 6-30 PSI
------ PHOTOS ------
Most Recent:
After 1" body lift and 35's:
April 2017 TOTM:
After Titan Swap:
Before Titan Swap:
Before Front Bumper:
Before Lift & Tires:
With Trailer:
Sticker Added:
100% stock the day after purchase... (after obligatory off-road trial):
AlbEdit
Xterra Name: Yoshi
Year: 2011
Legend:
[+] = Done
[-] = In progress
[ ] = Want
------ MODS ------
Titan Swap List:
Suspension/Lift:
Wheels/Tires:
[+] Airflow Snorkel
[ ] Inclinometer
Recovery/Comms:
Other:
[+] Trasharoo (Tan)
[+] Spare key safe
Most Recent:
April 2017 TOTM:
After Titan Swap:
Before Titan Swap:
With Trailer:
Sticker Added:
AlbEdit
