1 - 20 of 49 Posts
It started with a HF hitch rack, but now it's grown into so much more. Metal has been purchased, hardware is being bought, the chop saw has made an appearance, and the welder is anxiously waiting.
I'm working on completely reworking the rear cargo area, I'm annoyed by the hard plastic surface, having to tie everything down like it's going to ride on the back of a mule, and this useful but completely inaccessible space under the floor.
I'll go into more detail as the project progresses, but these teaser shots should give you all a good hint, but it's probably not what you think.
Wish me luck and put me to shame if I dawdle and don't get this finished soon with lots of photos. Actually at this point I have more money than I care to think about in this, I better finish it.
It's not drawers?
Not quite. Similar, but not drawers as we've seen done typically. I think I've run across only one setup that was very similar on here to what I have planned, but I'm doing some things differently with mine.
Discussion Starter #6 (Edited)
In the pics from yesterday I was sorting out some clearance issues where the threshold to the cargo area is slightly higher than the flat where the channel rails are.
On break I made a simple cutout on the mill to hopefully alleviate that so it can bolt flush with the floor yet will overhang to cover the slide. I just need too test for fit later.
For the slide mounts all that should be left is drilling thru holes for the floor bolts and slide bolts, and maybe attachment points for the next little feature of the project. (Optional at this point) And paint of course. I want to fit it all first before I do any finishing work.
Discussion Starter #9
Subbed and curious why you're not facing the L-steel the other way but will wait for all to be revealed.
Actually thanks for asking that because it prompted me to look back into it to remember why I did it that way, and you might be on to something, I may be able to flip them.
I wanted it that way initially for more width, but at the time I thought I was going to need to use the same L-steel for the inside of the slide as the steel bolted to the floor and was going to run into bolt heads in the way and such. Later I ended up going to a thinner and smaller L-steel (huge weight savings) on the inside, and didn't go back and re-check my clearances.
I might gain about 4" of width for the cost of raising some stuff up less than 1".
I still may run into a problem with the stupid bump that is on the threshold to the cargo area. The wider you go the more in the way it becomes. I think if I do flip it I've not done anything yet that will make anything I've done not work, but I need to mock it up that way in the truck and check for clearance issues.
I guess everyone is curious, but the big difference between what I'm working on and the typical drawer setup is I'm not going to enclose it like a box drawer. I'm just going to make a big flat platform that moves. RockyMtnX did something very similar except his sliding shelf went under another platform.
Then I'm going to try and rig up a HF cargo carrier shelf kinda like what a bunch of you here have done (I think @Longboardr is the one I referenced most) to attach on top. Really that is a separate task though, I'm going to make it part of my slide system but it would not need to be.
I still have a problem in that I don't want to eat up the space to the drivers side of the cargo area. I've found a tent cot, and/or a folding table fit perfectly there on end, and I don't want to mess that up. However it will probably be worth it to just find another home for such large items if I have to, I do after all have a huge GOBI roof rack.
I'm going to pick up some more supplies tonight, hoping to do some work over the weekend to get it where it looks like something. I know I won't get it finished but I'd at least like to get it roughly assembled.
Always glad to hear people get use out of a writeup.
Unfortunately I think you might find the HF cargo is going to be too wide to slide out of the back of the X. Assembled as intended to go into a receiver it's about 53 1/4" wide. You could assemble it without the 2" square tube, but I don't think it will clear even like that.
Actually thanks for asking that because it prompted me to look back into it to remember why I did it that way, and you might be on to something, I may be able to flip them...
That makes sense to keep it lower. Maybe just flip one side angle? That would keep your spacing for the table and cot but still allow some more width for the slide out, but like you mentioned it will raise it all up still. Are you talking about the bump for the latch? I found the large radii in the bottom corners of the hatch surround to be the most in the way. Also do you plan on taking the floor/lid out to make use of the compartment down there?
Discussion Starter #12
If I understand you, both bumps you describe are annoying me in different ways. The wider I go I get into the large radii, the further forward (toward me standing facing the cargo area) I get into that little bump. The cutout I show in the latest photos clears both now, if I flip flop them it might still, I was a bit generous with my milling so I had a little breathing room, I can also move them rearward a bit possibly. I'm going to look and see before I decide. If you look at the first post photos, you see where I was trying to get away from them with an angled cut, but it wasn't nearly enough.
You are correct, the existing plastic floor panel will be removed before I install my new sliding platform. When the sliding platform is pulled out of the truck the entire under floor area will be exposed behind it. Actually the whole idea would be kinda wasteful if not for that little feature. Might be a bit of a reach, but a lot easier to access than emptying the cargo area. I actually would not store anything under there before, with the new setup I'll put infrequently used items under there.
The sliders lock in and lock out, so when I open the rear hatch the platform is locked and won't come sliding out at me unless I push down on both tabs. They are also rated to hold a 500lb load, so I'm hoping it's overkill for my use and should be comfortable with all my gear.
If I'm on level ground, I can pull it out to me and lock it so my stuff is closer and I have a table area under my rear hatch overhang. Most of my camp cooking supplies live there anyway, and if I calculated correctly, there is room for my cooler now as well on the platform. Before putting stuff in there made it hard to access, but when the cargo area comes out to you, my thought is it will be much easier to access stuff, and I can get away with putting some items toward the back without them being trapped.
Or that's the plan anyway.
Discussion Starter #13
Thanks for posting it up, kind of the reason I went ahead and opened this thread in case anyone wanted to get some ideas. The discussion has been helpful in working out some details as well.
I probably described my intentions wrong, I woulden't intend for the HF rack to move. I am intending to assemble it without the 2" tube though, and try to offset it to the passenger side to see if I can still fit tall slim items in the drivers side like I was mentioning about my cot and camp table.
Right now I'm thinking of putting it on legs and making tabs off the slide rail mounts to bolt it to. I would like it to be kinda removable though, woulden't need to be quick but undo some bolts and set it out kind of deal.
Discussion Starter #14
I'm slowly working with it today.
@Hawk136439 I debated the angle wall inside vs. outside and test fit that in the truck like you talked about earlier and decided to keep them inside.
I definitely think it can be done but its going to add additional work in clearances. It was very close. If you planned ahead for it and built in some extra room, I'm sure out could be made to work if anyone wants to make a similar setup keep it in mind. It will make the setup higher but not much.
Personally for my camping setup, I think I would find the extra space in the side areas more useful for small gear so I'm not to concerned about losing the extra platform space.
Discussion Starter #16
Done a little bit more today, got the inner slide / platform mounts cut.
I don't think I'm going to do anything about it, but the slant of the floor I read about in other threads is apparent when you pull the slides out, they tilt down. I don't think it's enough to be a problem but it is noticeable.
I saw a slide within a slide on expo so you had cargo slide then under it was a functional eating cooking prep table that slid out one fly more? I'm sure spacers could fix the slant. I've also always wondered if the need to level the table plays into the set up. If you have a rtt you would already be getting close to level anyways for sleep comfort anyways
Discussion Starter #18
Made some progress, have most of the metal work done.
The platform is test fit and in position. Works as planned and does not seem to rattle, once all the fasteners are in I expect it will only be more rigid. I only have the minimum needed to hold it in now.
Still debating on how to attach the upper shelf, might be able to share the bolts into the floor tracks, I'm not going to give up my clean mounting if I can help it. It's all one project but two separate pieces, I intend to make it possible to have the slide and shelf, or each individually if needed.
Major items next are cutting the plywood for the floor and carpeting it, and getting the hardware for the tie down system.
At some point once I'm sure I'm done with the metal pieces I'll smooth all the corners with a grinder and prep them for paint. I'm in no hurry for that since the cool weather has not been favorable for painting anyway.
Discussion Starter #20
Well it looks like Tapatalk photos crap out after a while? I'll have to make a hosted album and go back and edit them back in.
No pics from this weekend but I got some more work done. I ground my welds, smoothed the corners, wire wheeled the tray and got some paint on. It's gotten to cold to shoot spray paint when I have time to paint, so I'm kind of hung there until it warms up. (I'm far enough south even this late in the year I'll still get 60 degree days sometimes, actually today is perfect weather but I had to work and a cold blast for next weekend, ugh....)
The plywood floor is cut and fitted, feels very sturdy, and my carpet is cut also waiting on suitable temps to get glued. The carpet should give it a nice appearance and friction so items don't want to slide around.
Today I placed an order for cargo containment fixtures, carpet alone won't contain heavy objects off pavement. It's pretty neat stuff I hope works well for this application. This will be the feature that kinda makes it worthwhile, because a simple sliding platform isn't much unless what you put on it stays there. I wanted something universal and versatile enough to make custom fixtures to simply snap common items in, yet still be able to throw any odd or unexpected item on there and make it stay put.
1 - 20 of 49 Posts
