1 - 4 of 4 Posts
I have tried the airbag procedure to try and reset my airbag light, but no go. I have tried numerous time. Generally, after the 4th time, the light still flashes, except it flashes at a much slower rate. Is there a time limit of when you have to pull out the key from the ignition to sticking it back in? Anyone else have any ideas?
Hey I had this problem before and i couldn't get it to turn off. I knew the reason for mine being on was that i had my entire dash disassembled which meant that the passenger airbag light was disconnected and i ended up turning on my car on which it saw as an error and stayed in the memory. Even though I installed an aftermarket stereo the dealer said it would be no problem to turn off and so it took them like five minutes to do it for me.
1 - 4 of 4 Posts
