1 - 3 of 3 Posts
I'm sorry if this subject has been brought up before, but I couldn't find it anywhere. I am having problems with my airflow control settings, air is only coming out the front vents; it will not change to any other settings and I need the defrost. When the car is started, the air flows through the defrost for a few seconds but then immediately switches back over to the front vents.
Has anyone ever dealt with this sort of thing before and found the fix for it or is this something where I will have to take my chances with at the dealer?:confused:
Yep. Blend door motor or selector switch is bad, or you have a broken blend door itself. For mine, the position sensor in the blend door motor went bad. The replacement blend door motor was like $25 and it took me about 10 mins to change. Ymmv.
Awesome! Thanks for your help. I'm going to consult the FSM to try to do it myself, if you have any tips I would really appreciate it since I am a novice at this sort of stuff.
1 - 3 of 3 Posts
