II Gen Nissan Xterra Air Conditioning Information:
These are the factory specifications for the Manual Air Conditioning System. If you are recharging the system yourself you will need these measurements to refill the system properly. DO NOT overcharge the system or you will risk discharging the refrigerant into the air or damagin your A/C Sytem. The refrigerant is a noble gas and is hazardous to breath or come in direct contact with.
Lubricant
Description: Genuine Nissan A/C System Lubricant Type R (DH-PS)
Part #: KLH00-PAGR0
Capacity: 180mls (6.1 US fl oz)
Replacement of any individual A/C component will require the addition of 1oz of replacement lubricant. (i.e. - If you replace the condenser and the compressor you will need to add 2oz of lubricant back in the system.)
Refrigerant
Type: HFC 134a (R-134a)
Capacity: 1.54lbs (+ or -) .11lbs
Most DIY refrigerant kits are only 17oz, so if your system is empty when you are recharging it, you will need an additional 5+oz of refrigerant.
Pressure: 551.0psi (+ or -) 43.5psi
Lubricant
Part #: KLH00-PAGR0
Refrigerant
