1 - 4 of 4 Posts
Hey a few days ago my air conditioner was acting funny, I would turn it on and it would make that sound the engine makes when you normally turn the AC on but there was no air coming through, gave it like 5 minutes and it started working, well today it doesnt work at all and I have been miserable, its been between 100-110 degrees all this week and it will be like that till winter, anyone know of anything that may be wrong?
Need to diagnose the problem a little better. Do you get air flow just using the fan high without the a/c button being pressed in? Pop your hood with the engine running, press the a/c button and go look at your compressor. Is the clutch engaged? Could be you have a freon leak somewhere and the low pressure switch is preventing the compressor from engaging. Take it someplace and get some a/c gauges put on it and see if your freon pressure is ok.
1 - 4 of 4 Posts
