1 - 12 of 12 Posts
Hey y'all,
I'm going to replace my rotors in the coming weeks, and am wondering if there are any other recommended maintenance items or typical replacement items that I should hit while I have it jacked up and the wheels off. I have to clean out my wiper fluid reservoir because there's a bunch of leaf litter in there, so going to have to do that regardless.
Please let me know if this is more suited for the Breaks/Tires/Wheels forum.
Thanks in advance.
TNX Veteran
Make sure you clean and re-grease the pins on the calipers.
^^ this. I just had brake pads wear out after 20,000 miles and destroy my rotor cus a pin was seized and wasn't returning it to the right position.
Would be worth also adjusting your parking brake if it is having issues. Mine needs new pads, but I doubt yours does being a 2014. But there is more adjustment available at the rear than just in the handle.
Clean wheels, rotate tires, inspect brake lines, new brake fluid & flush, grease caliper pins and pad liners, adjust parking brake shoes to new rear rotor inner diameters...
Don’t let air in the abs pump
Don’t ask me how I know
Anybody know what scan tool cycles our abs pumps!?
Sent from my iPhone using Tapatalk Pro
Apply anti seize on the mating surfaces between the wheel and rotors....makes taking off wheels 10000% easier in the future. Rotate the tires while you at it, if you're due.
TNX Veteran
Wheel and rotors...? Does your wheel rust onto the rotor and get stuck or something? I don't think I've ever had that problem. Plus it seems like you can just kick the tire and knock it loose
Typically, yes you can just kick it off. I've never not been able to get one off but I've had some fight me. More important if you live in an area that causes a lot of corrosion.
I drove my Frontier through four winters in North Dakota and my Xterra through two now and never had that problem.
Don't take my word for it, lol.
Btw, I just helped my brother do brakes on this JK and we had to hammer off 3 out of 4 of them, so I do know what I'm talking. Some of the time anyway.
1 - 12 of 12 Posts
