For the cure on the squeak, Take off the Stabilizer bar bushings and swap em out with polyurethane at Autozone. I think it's the 1 and 1/4 bushing. You can also test my theory by just lubing them with Anti Seize or silicone or some other rubber safe lubricant (synthetic grease?) Put them back on, drive no squeak huh! Told ya! 20 min job. But the urethane will solve the problem totally. The right lube will last a long long time also. Can't recall the torque on re install Dan posted in his AC Lift post I think 20 Ft Lbs, but stick to that or you'll squish out the bushings.
Let everyone know that it worked.
MC
