1 - 5 of 5 Posts
if you stick with the same size tires as you currently have, you would likely only increase your total height by the claimed lift by the spacer which I think is 2"
speaking of clearance...I just picked up a 1980 CJ-5 with SOA + 2.5" lift springs and 40" Ground Hawgs. With the roll cage, I could only clear my garage opening trim by 1"(if that). Had to remove the soft top just to get in my garage.
1 - 5 of 5 Posts
