I think the part # was MX6070. They fit perfect and allow the extra travel, however you should replace the top bolt with a slightly smaller one. I think it's a 1/2 inch. Here it the thread on the install. But if you have AC coils you will have the pain of compressing the coils but not have to remove the UBJ's Just disconnect the top and bottom and they come out the bottom and go back in same way. You should follow my instructions on the rear pretty close, A lot of people PM me and wish they did as they damaged rear shackles trying to bang them out. Use the strap no bang needed, just milk it out with the jack and ratchet strap.
http://thenewx.org/phpbb2/viewtopic.php?t=85
Rancho's Poor fit and what 1 year warranty No warranty once you beat em in..
Pro Comp Adjust ables 4 wheel parts OTC lifetime warranty as long as you own the vehicle = No brainer.
It's your money!
Also remember, lifetime alignment at Firestone for front end after install.
Be aware about the TSB for the alignment bolts, Nissan must fix free if needed. (some are not adjustable)
MC
