ABLS uses the ABS sensors to detect wheel spin. If it sees one wheel spinning much faster than the other, it grabs the faster spinning wheel to slow it down to transfer power to the slower spinning wheel.
The only input the diff has on this is doing it's thing as an open diff, allowing one wheel to spin faster than the other when you go into a turn. The outside wheel needs to turn faster than the inside wheel.
Now, sure, it sounds like the ABLS is doing it job, but in the wrong case. my guess, if this is happening, the computer needs recalibrate. My guess though, there is nothing they can do for aftermarket suspension / tires, just like they can do nothing about the speedometer for oversized tires.
Your wider track would change this effect, so I can see it happening more now, but I have no idea why it was doing it before.
