1 - 3 of 3 Posts
Happy Monday! Just replaced my left front wheel bearing and ABS sensor assembly on my 2007 Xterra. In doing so, we destroyed the connector going from the chassis into the ABS sensor (basically between the wiring harness and ABS sensor). Trying to figure out a part # for that connector. Went to the Nissan dealer, but they weren't sure. Does anyone have any experience replacing that piece? Thanks!!
You can't replace just the connector. On the wiring harness side, it comes up as the whole section of the wiring harness (f that noise) and on the bearing/sensor side it just want's you to replace the sensor (again, f that).
I'd cut the connector out and solder it. Soldering these wires can be a little bit of a pain, but I have done it several times on mine. I took my time, dipped them in flux, tinned them as best I could and got a clean solder joint. I then heat shrunk everything. No more problems.
1 - 3 of 3 Posts
