1 - 5 of 5 Posts
· on line
I currently have the AC shackles and was thinking about adding
the AAL. Will the driveshaft still be ok to use? Are there any other
potential problems I should be aware of? And will this setup-
AAL and shackles still require the shims?
· on line
Everything else is ok.
If you change the stock shocks (to longer ones) you will need to extend the brake lines as well. With the stock shocks, they will not allow the rear to flex enough to have brake line problems.
1 - 5 of 5 Posts
