I have an '05 Xterra with a '10 VK from an Armada. Because of the swap the A/C fan was deleted. I have since moved to TX from WA. In this climate that fan is needed. Since the original does not fit (anywhere, I've tried) I got a 10" push fan to put in front of the condenser and radiator. I wired it with help from a tech from a local dealership. Well! I ran the Auto Active Test. When it got to the fan it started, and immediately stopped. I plugged in the old fan, and it also will not work. Ran the engine with A/C on high, no fan. I checked the fuses, one in cab (#8 I believe), and two under the hood (#14, #17 maybe, can't remember now). I have not tested the relay yet. Waiting for the weekend. Any ideas what I broke? Advise on how to correctly wire this fan?
Pic 1, pigtail on harness. It's not a nasty pic. They don't like my sausage fingers holding the wire! Hahaha!!!
Pic 2, pigtail on original fan.
Pic 3, wires going into old fan (probably unnecessary)
Pic 4, New fan.
Sensitive content, not recommended for those under 18
Show Content
Pic 4, New fan.
