1 - 4 of 4 Posts
Im at 72k, and in about a month Ill be changing the oil again
curious what else I should go after
around 60k I did the drivetrain fluids
68k it got brakes(an da full line flush), and a tranny fluid job at the dealer
I have to get under it to go after a heat shield rattle
I believe it got a belt at 58k, but Ill inspect it anyways
I replaced one Cam Position sensor in February(that was cold!) and Ill replace the other at this next oil change
I am hoping to do a IMS and plugs at that time as well
should I poke at suspension bushings ETC?
Ideally I would do shocks/struts leaf pack, but summer projects around the house, a new van, and a baby coming in December make that unlikely
that's a good reminder....I had the trans fluid done with the diffs.....at my mechanic, and the dealer did the coolant, not the tranny, while replacing a cracked CAT......
Discussion Starter #4
IMS, Plugs, and Pass side CPS changed out yesterday
oil and filter as well
bring on winter!
1 - 4 of 4 Posts
