1 - 3 of 3 Posts
06 xterra s. Had the Dealership insall the 7 pin wiring harness. When my trailer is connected all lights work (driving, turn signals, reverse). However there are no brake like. Metered the harness and found no power to the brake prong. I have had the X into the dealership 3 times, so far they have changed the wiring harness right from the front to the back and the BCM.
The problem still exists angry9:
Has anyone seen or heard of this problem? If so, what was the resolution? I would love to walk into the dealership and show them how to fix my X.
Did you check the fuse under the steering column?
It is in odd location and a small 10 A or so fuse. I think it was red.
Thanks for the tip. I took a look but could not see the fuse under the steering column. Where abouts is it under there?
1 - 3 of 3 Posts
